Originally Posted by Popsy
2. I don't know how cold it gets, but above 0°C that engine in good condition starts well (better than hot...). Sometimes the choke cable gets loose, so you think you put the choke but you actually didn't, it's just one screw to tighten. You don't need to keep the choke for long, you'll feel it easily. Some carbs had an automatic choke that liked to misbehave...memories, memories.
Just to be sure, yours is the 1364cm3 ? There was a 1330 something too, old OHV Simca engine, not the same animal.
3. Yup, and very easy to do (modify the odometer). The interior weren't the greatest quality, so if it's not worn, the odometer probably wasn't tampered with!
5. Pretty sure the original coolant was blue, unless what you call green I call blue! Grey/blue/greenish ...‚
6. From memory...vague memory, very easy to do. On the right side when you face the car, one pretty big drain plug you can't miss, and a refill hole, I think on top of the gearbox, but I don't remember exactly I admit. You don't even need special tools, just regular sockets.
If you can't find the appropriate oil then just don't touch it, as long as it doesn't leak. The gearbox (assuming you have the 5 speed) isn't finicky as long as there is oil in it.
Most likely 1364 cm3, it's a '91 model, and the Simcas were replaced in '88 or '89, and choke works flawlessly, I checked and you can feel the engine revving faster, only the plastic cover around it cracked a bit and it annoys the [censored] outta me, I'll most likely glue the plastic back one day.
I mean does the color of the coolant really matter? Maybe they ran out of green one and put blue one in your car, or vice versa, maybe the first owner changed it to green, but it seems to do it's job, though I don't know how full it should be, when I shine a light down the hole I can see the coolant just on level with some metal/wire piece, maybe that's too low or maybe that's how much there should be, nobody knows.
And yeah, for now the transmission works great, except the first gear seems to not be syncronised, so I can't put it into first when the car is moving at all, I know some really old cars had that standard, but this seems to be too modern to not have it, not a big deal for me though, since my second car was one of those old-timey ones which didn't have it, so I'm used to it.
