Looking for the most likely cause. My wife had this dual bulb, motion sensor unit installed 15 yrs ago. Since then, she's replaced bulbs once. So this time, changing bulbs would have been the likely fix. Today I installed new LED style bulbs (120 v). When the lamps came on, they were flashing like a strobe. Now that was unexpected. 10 seconds or so later they went steady. OK, maybe that was some sort of trial, burn in? After another 5-10 seconds they just stopped working altogether. They wouldn't come on again as the switch was cycled. No idea if the old lights failed together or one at a time a few weeks/months ago.
Did the fixture itself actually fail earlier and now it took out these new lamps? LED's not compatible? I figured someone here has experienced this or something similar. Not too keen about wasting another possible $11 in bulbs if the fixture is likely the culprit. Why would they even flash? At this point, I'd be thinking the fixture has a fault.
Thanks in advance for any tips.
