If you maintain your engine, its a coin toss.
If you want to compare, run a fix mileage/time run on each of the above filters, grab a UOA with particle counts, and compare the filters. Stick with the same oil for the test.
Don't believe in rumour that one is better then the other. Rarely can anyone provide such proof.
But, I do believe that some filters don't fit as well, or just look poorly constructed. Avoid them!
