S silverbullet Joined Oct 12, 2005 Messages 65 Location Northern California Aug 18, 2017 #1 Thoughts? Has anybody used it? Saw this on Autozone. http://www.autozone.com/brake-and-power-...luid/574701_0_0
RooflessVW Joined Dec 24, 2011 Messages 15,930 Location North Carolina Aug 18, 2017 #2 Saw it on the shelf at my local store, right next to Pentosin Dot 4 LV. I don't see why it wouldn't be anything but excellent in service.
P Pelican Joined Nov 28, 2012 Messages 1,982 Location Ontario, Canada Aug 18, 2017 #3 Originally Posted By: silverbullet Thoughts? Has anybody used it? Saw this on Autozone. http://www.autozone.com/brake-and-power-...luid/574701_0_0 What do they mean by extended service? One should change the brake fluid every 2-3 years even with synthetics.
S slacktide_bitog Joined Mar 20, 2008 Messages 19,105 Location USA Aug 18, 2017 #4 That looks like a great deal! Better boiling points and lower viscosity and a better price than Pentosin LV or any DOT 5.1! For reference, the DOT 5.1 minimum boiling points are 500 dry, 356 wet, max visc 900. The Bosch fluid is 518 dry, 365 wet, visc 670 I wish this was available when I needed it!
B bmwjohn Joined Jan 4, 2008 Messages 727 Location indianapolis in Aug 18, 2017 #5 hmmmm. We just did the brakes on 1992 245. Used Valvoline DOT 4 synthetic. Wonder how much better this would be? Replaced 4 calipers, 4 premium Raybestos rotors, rebuilt M/C, Wagner premium ceramic pads.
Carmudgeon Joined Apr 26, 2005 Messages 2,292 Location Under the hood Aug 18, 2017 #6 Looks like Bosch may be repackaging a slightly different version of ATE SL6, down to the tin can container. The boiling points are a bit higher than SL6 (509/347; 700), though Typ200 is a bit higher still (536/388) but not a low-viscosity fluid. For those who need a readily-available, high-performance LV fluid, this is good news.
edyvw $50 site donor 2026 Joined Mar 8, 2012 Messages 29,787 Location Colorado Springs, CO Aug 19, 2017 #7 This is probably made by ATE for Bosch. Not sure is color clear or it is dyed like good ole SL6? That was best thing.
