Boron Question
Australia
Hi all, just another quick question, this time about Boron used in oils.
Again I'm sure it's been asked before, but a search showed nothing.
What's the go with Boron, some oils have a bit, and no molly and some have none at all, with a little molly.
Is it a good quality to look for or not the important in the over all package.
I recommend you check out the VOA section, you'll see what additives are used by which motor oils, then by checking the UOA sections you can begin to discern for yourself about additive packages and different oils and how they perform in different engines. Use this same response to the next question you ask in this forum (magnesium). Hope this helps you out.
