Originally Posted by billt460
Originally Posted by Lolvoguy
I was under the impression that turbo technology has advanced leaps and bounds over that of what was offered in the 80's.
What gives?
It's really pretty simple when you lay it all out. There are several big problems turbo's have a very difficult time overcoming. And that is any performance gain worth their added cost and complexity. A very good example of this, is in the comparison of the new 2018 V-6 Toyota Camry vs, the 2018 Honda Accord 2.0, 4-cyl Turbo. Both are very similar vehicles. The Accord is no longer available with the V-6 engine option. It has been replaced with a 2.0L, 4 cylinder turbo. Which supposedly offers the latest and greatest in turbo technology.
Yet when you compare them up and down the line, the turbo offers little to no advantage. And several disadvantages. First off, the turbo 4-cyl Accord costs over $1,700.00 more. In spite of the fact it produces almost 50 less horsepower.
And it gets the exact same fuel economy as the V-6 Camry. So where is the advantage of the added cost and complexity of the turbo? It doesn't exist.
Not only that, but which one will be more desirable, and less risky to own, when both are sitting on a dealers lot, out of warranty with, "Pre Owned" plastered across their windshields? Used turbo equipped vehicles out of warranty are very difficult to sell. Unless you get them cheap enough for someone to be willing to take on the risk of costly repairs in the event of a turbo failure.
The only way the manufacturers can overcome this added repair cost and risk, is to provide much longer and better warranties on their turbo equipped vehicles. In order to take this risk out of the equation for people shopping for a used turbo. Thus far they have not done it. The reason is the same for them as it is for the used turbo purchaser. The risk is simply not worth it.
2018 Camry XSE V6..... 2018 Accord 2.0T Sport Touring
MSRP (Base): $34,940..... MSRP (Base): $36,675
Engine: 3.5L V6 w/D-4S Dual Injection..... Engine: 2.0L Turbo 4-Cylinder
Transmission: 8-Speed Automatic...... Transmission: 10-Speed Automatic
Horsepower: 301 @ 6600 rpm..... Horsepower: 252 lb-ft @6500 rpm
Torque (lb-ft): 267 lb-ft @4700 rpm..... Torque: 273 lb-ft @4000 rpm
MPG: 22/32/26 (city/hwy/combined)..... MPG: 22/32/26 (city/hwy/combined)
Safety: TSS-P w/ Pedestrian Detection..... Safety: Honda Safety Sense w/Speed Limit Sign Monitoring
Curb Weight: 3,572 lbs..... Curb Weight: 3,428 lbs
Airbags: 10..... Airbags: 8
https://www.haleytoyota.com/2018-camry-vs-accord-comparison/
Please man. Toyota's V6 are absolutely average engines. On top of that, that new DI V6 is actually IMO step back compared to 2GR-FE in Sienna I have. But even 2GR-FE is not anything special. It is dead at lower rpm's, it is mediocre at mid range, and has very short torque curve at high rpm's. On top of that, turbo's are much, MUCH better at high altitude. That new V6 in Toyota IMO is lacking power in all rpm range due to Atkinson cycle.
Turbo engines are fine as long as you maintain them in same way as your average V6. Average turbo engine is not N54 from BMW which was technological bomb when it got out and naturally carries risks. But then, turbo's are present in diesels forever and I do not hear people calling for naturally aspirated diesels.
Now, truth is that Honda really messed up 1.5T when it comes to fuel dilution.
I on other hand for last 20 years drive VW turbo engines, and yet to have an issue.
