Just bought a really nice, professionally rebuilt '76 BMW. Don't know much about them, never ridden one. Anybody with BMW motorcycle experience?
Thanks Chief!Owned “Air Heads” from 1959! to 1981.
Most important thing I can advise you is to keep the output splines between the clutch and transmission lubricated. Not easy to do. You have to pull transmission back a bit and brush on grease. Some guys just removed transmission to do the job. These splines are a wear item.
Use Premium fuel, otherwise the bike will “Ping”. If it continues to ping, install thicker base gaskets, or two regular base gaskets under each cylinder.
Bing carburetors are easy to clean. You don’t even have to remove them. When it starts to run ratty, remove float bowl, get on your back and squirt carb cleaner into the two jets. You can also remove the tops of carbs and move jet needle up (richer) or down (leaner), by twisting needle and moving to the next groove.
The beauty of the /6 (or /5 or /7) was that you could fix or correct almost anything while on a trip.
Sold my last one (R65) in 1981 but still love those Beemer Airheads.
BTW. Beautiful Bike.
Very true. I've been in both categories. Rode a 350 Honda to work almost everyday in Chicago even through the winter. Didn't have a car. Did two cross country trips just for the adventure. Now I ride a couple of times a month just to keep the bike limbered up. Doubt I'll ever go on another long trip.The people that only ride less then 2k miles a year and like to keep it polished, to those who's only mode of transportation is their motorcycle. Those who put heavy miles per year on their bike ,want to know which tires last the longest, which oil tends to hold up the best in their model. Which brakes give the best service life and so on.
I’ve never used soft bags on my bikes, so I'm not an expert in which of these works best for particular purposes, but your bike is short a couple of accessible anchor points for "throw-over" soft bags, because the aftermarket "king/queen" seat lacks the OEM passenger grab handle. But it may be a non-issue; there are probably soft bag attachment methods that can overcome this.Señor khittner, very keen observations. Just a few general questions. I need to add some luggage capacity. The entire mounting frame and hard BMW cases are prohibitively expensive. Do universal soft travel bags fit well onto an old BMW? I've located a luggage rack on Ebay that would hold a top box but I don't know if it can mount to the bike independent of the entire luggage frame.
I was told that these models are reliable and require little maintenance. Is that your experience? I'm an old rider, not a bold rider so speed is not an issue.
tks
I read AV gas works best in the old ones.
Thank you sir. I am a vintage rider with a vintage motorcycle and a vintage knowledge base. I appreciate your input.And welcome to the airhead subculture! The motorcycles remain quite useful machines, and you have an example that'll need less work than many to keep nice.
All yes but…the R50/5 was far smoother than the 600 and 750cc BMWs. I put over 100,000 miles on examples of all three and the R 50 was like an electric engine. With so little reciprocating mass it had to run smooth. The R50/5 was not to common in the performance slanted USA but was a “third world” popular bike. It ran on regular gas and shared all parts with the bigger bikes that were not in the cylinder or head. I bought one in Houston with a HEALTHY discount as the dealer said he could only sell the big 750. $1200 out the door.I own two airheads, an '84 R100RT, and a '91 R100. I've previously had similar vintage ('75 and '76 /6 Series) R90S and R90/6 bikes. Been riding BMWs since '82, but not a mechanical wizard; I'm a reasonably well-informed owner.
Your bike has a couple of visible mods (aftermarket seat, /5 mufflers, and the later handlebar-mounted brake master cylinder), which aren't problematic, and the 750cc engines were the smoothest running engines among the several models, so, from what I can see in one photo, it looks like a reasonably nice example of a desirable "keeper" model. What are your questions?
