Code:
Date 5/5/05 10/5/05 3/6/06 6/6/06 3/7/07 6/7/07 3/8/08 9/8/08 10/8/08 6/4/09
Miles 5011 5000 4300 5958 4514 5347 5017 3839 7250 5100
Total 21130 26100 31407 37365 41879 47226 52245 56084 63334 68400
Make up 0 0 0 0 0 0 0 0 0 0
Oil BMW Castrol Castrol BMW Castrol Castrol Castrol Castrol Red line Red Line
Weight 5w-30 0w-30 0w-30 5w-30 0w-30 0w-30 0w-30 0w-30 5w-40 5w-40
Filter BMW Mann BMW BMW Mann Mann Mann Mann Mann Mann
ALUM 4 2 2 2 2 2 4 2 2 4
CHROM 1 0 0 0 0 0 0 0 0 0
IRON 9 7 6 4 8 6 11 9 7 7
COPPER 28 22 15 18 22 8 15 9 5 17
LEAD 2 2 2 1 1 1 1 0 0 0
TIN 0 1 0 0 1 1 0 0 0 0
MOLY 124 19 4 104 16 4 3 2 3 149
NICKEL 1 0 0 0 0 0 0 0 0 0
MANG 3 1 1 1 1 1 2 1 1 1
SILVER 0 0 0 0 0 0 0 0 0 0
TITAN. 0 0 0 0 0 0 0 0 0 0
POTA 9 1 6 1 2 0 8 3 2 3
BORON 38 9 3 21 4 2 3 2 1 4
SILICON 5 3 3 3 3 2 4 3 4 6
SODIUM 2 4 3 5 3 3 4 2 3 9
CALCIUM 3446 2125 1704 2463 2702 2985 1864 1891 2452 2142
MAGN 18 311 455 83 129 147 448 551 86 30
PHOSP 853 748 781 662 737 782 872 885 988 1032
ZINC 1050 889 964 847 878 1001 1115 1087 1282 1228
BARIUM 0 0 0 0 0 0 0 0 0 0
SUS 65.6 62.5 63.2 64.1 63.8 65.8 64.2 65.5 73.9 78.2
cSt 11.76 10.91 11.11 11.35 11.27 11.82 11.38 11.75 13.97 15.08
Flash 375 375 325 415 360 395 380 400 440 385
Fuel %
Antif % 0 0 0 0 0 0 0 0 0 0
Water % 0 0 tr 0 0 0 0 0 0 0
Insol % 0.3 0.3 0.2 0.3 0.2 0.2 0.2 0.3 0.3 0.3
TBN 1.8 4 4.7 3.2 2.9 2.6 2.9 4.9 4 1.7
Blackstone comments-
SCOTT: Copper, from brass or bronze parts increased in the latest sample from your BMW. Copper has
been high in the past, yet sporadic, so it could just be an engine bushing wearing a bit more than usual. At
17 ppm, it's not reading that much above averages for the 3.0L, so we'll take a wait and see approach
before we call it a problem. All other wear looked great. A trace of gas was found, which isn't a problem.
The viscosity was a bit high, and we're not sure why. The TBN was 1.7, quite low compared to the last
sample. Due to these, try just 5,500-6,000 miles next.
Another Houston Winter UOA, wonder if copper has to do with the winter fuel blend and increased fuel dilution?
I am surprised BlackStone flagged the viscosity at 15.08 since they did my VOA and it was 15.15. I must have had a quart or two of the older formula to have Moly at 149.
Still running the oil, drove 1060 miles Saturday, will add another 1000+ Friday or Saturday. Will send a sample when I change it then.
Should be close to 7500 miles total by then. Will the TBN still be higher, I added about half a quart after this sample to replace what I pulled to bring the level up to full.
Fuel %
