This may seem like an odd question but it has a point. I have a 1988 for Escort EXP with a very stout ford CVH H.O. motor. I was going to swap he dizzy over to a EDIS ignition system. The best way to do this is by installing a second gen US escort under drive crank pulley, oil pump and crank trigger. It all bolts on and the under drive crank pulley is the same size as the first gen rank pulley. BTW the crank trigger mounts on the oil pump hence the different oil pump.
Only problem is that the second gen oil pump has a spot for the oil filter wile on the pump wile the first gen motor has the filter on the block.
This setup wold lead me to having two oil filters. Would anyone have any advice on block or by passing the oil filter port on the block ? I'm guessing the simple fix would be to run two filters. But I'd like to get rid of the filter on the back of the block as it sit right above the exhaust.
Thanks for the help.
