Bleeding Brakes - what's the most effective way?
SE MI
the 3 person approach: one under car to tighten/loosen bleeder screw one refilling the reservoir one pumping the pedal the mity-vac pump or speed bleeders? I need an effective way of getting rid of air in the fastest possible way w/ the least amount of manpower.
Richmond, VA
No need for the third person. Have one pump the pedal while the other turns the bleeder screw. Check level frequently. Do not pump the pedal with the cap off the reservoir. Fluid will go everywhere. Use only mfg. recommended fluid. Most use DOT 3. [Cheers!]
TC
California
The two-person approach is probably fastest, but the Mity-vac pump works fine if you're working solo.
par
usa
Motive Power Bleeder. I can change my brake fluid in about 15 minutes, single handed. Notice I said 'change' and not just 'bleed' my brakes.
Nothern USA
quote:
Originally posted by cangreylegend: Don't forget every vehicle has a best sequence of which wheels are first, second, third and fourth. It varies.
Good point. I don't understand why, but they do. When we rebuilt the calipers on the Grand Am, and I checked the shop manual before bleeding them, my teenage son said, "Come on Dad, you have done this before, you know how". I said, "Not this car".
BlueOvalFitter
Site Donor 2022
Cajun Country, La.
I read somewhere that its a good idea to put a short 2X4 on the floor so when you are pumping the pedal it does not go all the way to the floor,causing the master cylinder piston not to bottom out.Anyone else heard of this tip? [I dont know]
Nothern USA
Excursions into seldom visited territory may not be good for older master cylinder cups and power brake units. You 2'' X 4'' may slow the job down, but prevent additional problems. [ December 19, 2003, 09:14 AM: Message edited by: labman ]
Simpsonville SC
I've done all three methods, settled on the Speedbleeders. By far the easiest and quickest for me. I tried my friend's Motive Power Bleeder but my resevoir is odd shaped and was kind of a pain to set-up. That caused some minor fluid leaking too. As was mentioned, best to avoid bottoming the pedal.
palm beach
you can let gravity do your dirty work if you like. put a hose on the bleeder, and crack it open. assuming the bleeder is lower than the resivor, gravity will change it out. if not, then drill a hole in your resivor cap and install a valve stem off a wheel. pressureise a couple psi to overcome grativy.
Seattle
I am really happy with the Mity-Vac, works great for me. The sequence I use is start at the brake with the longest line, then to the 2nd longest and so forth. I also think pushing the master cylinder piston past its normal operating range can cause damage. Anyone have more info on this "speedbleeder" dealio?
Nothern USA
The Mity-Vac can be a good deal for most people. I have made do by having my wife or kids pump the pedal. Most wives will tolerate that sort of thing occasionally. At least enough for necessary work. Do not ask them to crawl under the car and do the bleeding. The speed bleeders have a large reservoir of brake fluid in an air tight container. There is a hose from the bottom to a selection of adapters that fits older master cylinders, but not the one on your car. You manage to hook it up anyways, and pressurize the container with compressed air. Then you can go around to each bleed screw, and open it until decent looking brake fluid is coming out air free, and close it. If you are planning on still having the car the next time it needs brake work, remove, clean up, and coat all the bleed screws with silicone grease before you start. They work great, but are a bit of aa pain to set up. They also take a lot of fluid to fill, exposing it to air and moisture. If you are not using it every day, you either end up using old fluid, or throwing a bunch away.
Nothern USA
Sorry, I confused the Speedbleeders with the power bleeders. I still think the old 2 person way or the vacuum pump is the best idea for those that work on their own brakes when needed. The power bleeders only make sense for somebody maintaining a number of vehicles. Not impressed with the Speedbleeders. They may be OK for somebody that is continually messing around for lack of useful ways to occupy their time.
