Originally Posted by jay929
I saw a video of some guy putting tubing in a water bottle filled with some brake fluid and bleeding it himself. No air bubbles cause the tubing goes in the brake fluid. Does it work well or should I just drag my old lady in the garage with me to help
It works and works well. I've been doing it for YEARS. It's crucial, of course, to ensure the tubing stays in place on the brake bleeder itself. Thus, if you are doing this by yourself, chose the right size tubing for a tight fit on the brake bleeder, and when you push on the brake pedal, do it s-l-o-w-l-y. You are only trying to get the fluid out; there's no need to rush that aspect of the task.
And since you mentioned you wanted to avoid having to "drag the old lady into the garage," I decided to go with the one-man/person method because the one-and-only time that I asked my wife to be act as the brake pedal pusher, when I said, "OK, push now, " she replied, "I am. The pedal's going straight to the floor!" "What!?" I yelled. As you may have guessed, despite my explicit instructions regarding her role and task, she was pushing on the clutch pedal.
PS: If, instead, you are considering using a Motive bleeder, they work well enough on German cars. They, however, don't work worth a [censored] on Hondas where you have to fashion a Rube Goldberg arrangement to lash the bleeder to the master cylinder.
