Anyone tried Blaster's Lawn Mower Tuneup? I bought some the other day while at the local hardware store, getting some fuel line and some more PB Blaster. I figured, what the hay, Blaster makes some pretty decent products, I will see how it cleans up my neighbors neglected leaf blower that he could not start and asked me to look at.
You take the spark plug out, spray the stuff in the cylinder, put the plug back in loosely, turn the engine over a few times to distribute it in the cylinder and let sit for about 15 minutes. Tighten the plug and put the wire back on then fire it up.
Stuff works pretty good for removing carbon and unburned fuel from 2-cycle piston tops. Thought someone would call the F.D. with all of the smoke!
Smoke cleared up in about 5 minutes of running. I let it cool down and pulled the plug and took a look inside. It removed about 30-40% of the fouling. To fix the no-start, I had to rebuild and clean the carb.
Would I recommend it? not really. It does work pretty good as a mosquito fogger. For someone that does not want to tear down an engine to clean the carbon off, you may want to try it.
I have not tried it on a 4-cycle yet, and it is not a miracle cure.
Dave
