This is on a late 90s 351W with nearly 200k, running quaker state high mileage at the moment. I have been doing a series of short flushes with a variety of syn/conv to try and clean out crud left from the previous owner probably not changing the oil often.
Overall, the entirety of the oil turns dark quickly in an OCI, but I notice that right after changing oil I get a thin black line of dark, perhaps sooty oil right at the top of the hash-marks when checking the level on a cold engine. below the line is normal honey colored oil like you usually get in the days after a change.
I figure if it were cleaning carbon from inside the engine, it would uniformly darken the oil, but with it being on top, it is some sort of carbon dripping down from above and staying on top of the oil. Then when I check the engine cold before starting it the black line shows up.
Tis is a 90's engine, so on the list of carbon suspects are 1. the EGR system, which fills the intake manifold with black carbon. 2. the PCV system. 3. Perhaps there is burnt oil getting cleaned up under the rocker covers dripping down over night. And finally, 4. would a leaking injector wash combustion chamber carbon down and leave a black layer suspended on top of the rest of the oil?
Changed spark plugs and all were old, but within spec and indicated normal burn.
Anyone ever ran into this before?
