I put them around the corner while they inflated to 8.5 bar/125 psi.
Had one or 2 that destroyed themselves, both just came back from rethreading
It's usually a very thin layer and is called Black Ice because you can't see it, so don't know it's there until it is too late."Black ice" is basically just frozen water on the road surface which becomes a layer of ice. I've seen a 1/4~3/8 inch of ice on the roads from freezing rain.
Black Ice is water that has frozen and you can't see it. It is probably the most dangerous condition on the road.I was watching a show on NATGEO called HIGHWAY THRU HELL. They were filming in British Columbia during a winter storm. Their focus was mainly on a highway named The Coquihalla Highway. The roads were layered with black ice and snow. There were some very serious accidents because of the Black Ice. There was even a fatal crash.
Black Ice, what exactly is it and is it as deadly as they say? Does spreading salt on it help at all?
When I was 17 years old I had driven to Baton Rouge to visit my sister. It was just after Christmas and it was like 22*. Before I left from her house at about 1 AM my 69 F-100 drivers side door was frozen shut. After pouring water over it and into the seams it finally opened. My sister suggested I stay the night due to the roads being frozen, maybe.
As I was driving down a busy road (normally) the light began to turn red. When I applied the brakes my truck started sliding and spinning in circles. Luckily, there were no other vehicles on the road. When I finally stopped, I was facing in the direction I was driving from. Do you think it was black ice that I drove over?
That was just a case of ice and snow covered roads and going uphill. With that bus, a) he had pretty darn good tires and b) he kept momentum. Going DOWN that curved hill would be much more challenging !Lol like its no big deal! Wonder if that bus was AWD?
You're not supposed to use c/c on wet roads either.One thing I didn't see mentioned in skimming the thread, is don't use cruise control when ice is a possibility. Hitting ice with the cruise control engaged will get your attention, then it's a just a question of whether you can regain control before crashing.
I'm sure that's true for older cars without traction control and stability control. New cars can switch that cruise off faster than you realise you need to lift your foot off the gas. Not so sure it's still a bad thing to do. Try hitting a puddle at speed and see what happens if that one tyre starts aquaplaning with CC on...One thing I didn't see mentioned in skimming the thread, is don't use cruise control when ice is a possibility. Hitting ice with the cruise control engaged will get your attention, then it's a just a question of whether you can regain control before crashing.
My 370Z did that in dry weather on the highway once the road was so rough when it lost traction (doing the speed limit). Louisiana is such a trash state, lol!I'm sure that's true for older cars without traction control and stability control. New cars can switch that cruise off faster than you realise you need to lift your foot off the gas. Not so sure it's still a bad thing to do. Try hitting a puddle at speed and see what happens if that one tyre starts aquaplaning with CC on...
See the slushy stuff next to your tire ? Odds are that's what most roads will look like or will be in even better condition. The heat, friction, etc from traffic frequently get rid of it so I wouldn't presume your roads will be ice rinks.Black ice looks like this.
So.. I'll be driving home on a donut on black ice. Cool.
This is the black ice in front of my car before I moved it.
exactly, but those who are driving a newer car could actually be better off with CC than with foot on the gas if slippery. Mind you, there's often a minimum speed to activate CC and that could be too high for use in slippery conditions...Not everyone is driving a newer car with all the driving aids. Of course I wouldn't use C/C in rain where standing water is a possibility either. I just didn't mention it as the subject of the thread was ice.
Honda has plenty of driving aids on their modern vehicles and in a box labeled "Warning", they say (bold and italics added by me):but those who are driving a newer car could actually be better off with CC than with foot on the gas if slippery
Use the cruise control only when traveling on open highways in good weather.
