black gear lube in a ford
I have a related question. The first owner of my Jeep 4.0 changed the axle lube within a few hundred or thousand miles of factory new. He used Mobil 1 75w-90. When I drained the M1 75w-90 at 50Kmi, front and rear lube was black. I replaced the fluids with M1 75w-140 at the FSM recommendation for severe service.
What caused the M1 75w-90 to turn black? Was it the fact that the axles were still breaking in or some other reason like excessive heat?
-brian
The blackness or darkness of the fluid is due to the large amount and type of sulfur additive used in the factory gear lube.
I was discussing this with an additive supplier the other day and he confirmed this fact.
Moly gear lubes such as Schaeffer's #267 are very dark due to the moly's as well.
Can I expect the replacement fluid to turn black also, or do they use a different formula lube during assemlby?
