I've been digging through old threads here for an hour or so looking for oil filter recommendations for my 93 Altima. So far, I haven't really gotten any good sources of info relating to a rock-solid recommendation of a filter for my car. Does my 93 KA24De need a bypass valve in the oil filter? Using the Fram recommendation, PH3682 then cross referrencing that on Baldwin's website, I get their B113
filter. This one doesn't state the bypas valve's psi rating, so am I correct in assuming this filter doesn't have one? This filter is a good length, but if it doesn't have a bypass valve, maybe I should avoid it. The Baldwin B1402
does appear to have a bypass valve, but it's almost an inch shorter than the B113. Should that concern me? Also, these Baldwin filters make no mention (on the website anyway) about the ADBV, I assume these ones are Nitrile. Should I perhaps consider a filter with a Silicone ADBV instead, or would the Baldwin filter work just as well?
