Does it have to be in a PureOne? There are two quart Chevy filters ..but I think that they're the bigger gasket (old) style. They don't come in a PureOne, iirc.
There are a few 5.xx" long filters.
L30015 - no PureOne (has bypass ..but so what? Your in block bypass trumps it)
L30005 - no PureOne
Here's all the 13/16-16 thread filters from Donaldson. You can try the numbers in Wix and Purolator ..but those above were the 5.xx" versions with your gasket size.
P166564
LUBE SPIN-ON FULL FLOW
A - OD (Inches) 3.73
B - Thread Size (Inches) 13/16-16
C - Length (Inches) 5.37
D - Gasket OD (Inches) 3.45
E - Gasket ID (Inches) 3
Product Type Description LUBE SPIN-ON FULL FLOW
Primary Application GM CAR & TRUCK
Application Note SYNTEQ Media
Substitution P550035-Standard Lube
Product Group F
P550020-288-002
SPIN-ON LUBE FILTER
A - OD (Inches) 3.66
B - Thread Size (Inches) 13/16-16 UN-2B THREAD
C - Length (Inches) 5.35
Product Type Description SPIN-ON LUBE FILTER
Primary Application SCANIA 1329876, 1381235
Product Group F
P550020
SPIN-ON LUBE FILTER
A - OD (Inches) 3.81
B - Thread Size (Inches) 13/16 - 16
C - Length (Inches) 5.53
D - Gasket OD (Inches) 2.81
E - Gasket ID (Inches) 2.42
Relief Valve Setting (PSI) 18 - 23
Primary Application JOHN DEERE AR58956, T19044
Product Group FL
P550024
LUBE FILTER
C - Length (Inches) 5.22
D - Gasket OD (Inches) 2.82
Anti Drain Valve (Y/N) Yes
Primary Application ALLIS CHALMERS, CASE, IHC
Product Group F
P550025
SPIN-ON LUBE FILTER
C - Length (Inches) 4.22
D - Gasket OD (Inches) 3.38
E - Gasket ID (Inches) 3.04
Product Type Description LUBE SPON-ON FULL FLOW
Primary Application GMC 6 CYL. & V8 GAS
Product Group F
P550035
SPIN-ON LUBE FILTER
C - Length (Inches) 5.12
Primary Application GM, AC PF35
Substitution P166564 Is Synthetic Media
Substitution 2 Version
Product Group F
P550188
LUBE SPIN ON
A - OD (Inches) 5.44
C - Length (Inches) 5.44
Relief Valve Setting (PSI) 8-10
Primary Application CUMMINS 170200
Product Group F
P550505
A - OD (Inches) 2.96
C - Length (Inches) 4.45
D - Gasket OD (Inches) 2.77
E - Gasket ID (Inches) 2.36
Primary Application GM LIGHT TRUCK, AC PF59, PH59
Primary Application 2 PF58. PH58
Product Group F
P550507
A - OD (Inches) 3.77
C - Length (Inches) 3.08
D - Gasket OD (Inches) 3.57
E - Gasket ID (Inches) 3.16
Primary Application GM LIGHT TRUCK, AC PF454,
Primary Application 2 PH454
Product Group F
P550518
LUBE SPIN-ON
A - OD (Inches) 3.69
C - Length (Inches) 5.36
D - Gasket OD (Inches) 3.48
E - Gasket ID (Inches) 3.10
Relief Valve Setting (PSI) 11 - 17
Product Type Description LUBE SPIN-ON FUUL FLOW
Primary Application GM V8 6.6L DIESEL, AC PF2232
Product Group F
P550551
LUBE SPIN-ON
C - Length (Inches) 4.34
D - Gasket OD (Inches) 3.44
Primary Application WISCONSIN RV51
Product Group F
P550598
LUBE SPIN-ON
A - OD (Inches) 2.92
C - Length (Inches) 4.83
D - Gasket OD (Inches) 2.73
E - Gasket ID (Inches) 2.43
Primary Application GM 25010324
Product Group F
P550599
LUBE SPIN-ON
D - Gasket OD (Inches) 2.83
E - Gasket ID (Inches) 2.46
Primary Application GM 6437462
Product Group F
P550832
SPIN-ON LUBE FILTER
C - Length (Inches) 7.87
Primary Application GMC 6439034
Product Group F
P550964
SPIN-ON LUBE
A - OD (Inches) 3.78
C - Length (Inches) 5.14
E (Inches) 3.04
Product Group F
P551307
LUBE SPIN ON
A - OD (Inches) 2.99
C - Length (Inches) 3.41
D - Gasket OD (Inches) 2.84
E - Gasket ID (Inches) 2.47
Primary Application GM 6439857,25010325
Product Group F
P551764
Primary Application GM 6438868
Product Group F
P551764
LUBE SPIN-ON
Product Group F
P552463
LUBE CARTRIDGE FULL FLOW
A - OD (Inches) 3.660
C - Length (Inches) 3.790
D - Gasket OD (Inches) 3.444
Product Type Description LUBE CARTRIDGE FULL FLOW
Product Group F
