- Messages
- 187
- Location
- California
Hi I'm new to this forum and I hope I'm not bringing up something that has been discussed alot in the past.
One of our deliverly trucks has a 454 /TH400 with 3.73 gears.This truck is forced to see alot of low speed ( low RPM ) stop and go use.Often times barely getting up to 180 deg water temp and then shut down... It travels from one of our locations to the other and back within the same city.So it would seem that even tho it see low amounts of mileage it's use would seem to harder on the engine.
The last truck we had that was basically the same use used dino 30 weight.The oil was changed every 1000 miles or so and when the engine was disassembled it looked quite good.
The typical weather here rarely gets below 40 deg F and typically doesnt get much above 98 deg F during the hours of truck use.Most of the time between 50 and 85 deg F as a yearly type of spread.
Given these parameters what would you guys suggest as a proper oil for this trucks use ?
Thanks....Calvin
