quote:
Originally posted by Johnny:
Just bought 3 new Trek Bicycles yesterday for the family and was wanting to know what any bicycle experts recommend for lubrication. You know, the chain, cables, etc.
Mtn bikes? Road bikes? What kind of roads &/or trails? Riding all year in all kinds of weather or just on nice days?
Augh! Too much to know!!!
OK, for dry weather on roads, WL is great on chains. But I don't like its lack of water protection. For occasional water interaction, I prefer Finish Line's dry lube. For heavier water dousings I go with Tri-Flow. And for snotty, slushy rides I use One Lube 'cuz it resists washing off the most. On trails, I usually use Finish Line dry lube 'cuz it offers a good balance between keeping dirt off
and keeping water out. But I usually ride trails when they're dry, so I don't have to deal with mud in my chain. If I knew I was going for a mud ride, I'd probably use One Lube.
For cables, I prefer DuPont's Teflon Drivetrain Lube (in the earlier link). But unless you find it at a Bike Swap somewhere, you'll never get any 'cuz they don't make it any more. My next choice is Finish Line (dry again), or one of those liquid graphite lubes for locks.
Seatposts get a very, very light coating of not-too-slippery grease, so that you don't have to over-tighten the clamp just to keep it from slipping down on you. Waterproof is good too, since the rear tire will throw junk against it. I usually use Phil Wood Waterproof Grease 'cuz I have some, but I think Lano Lube would be great here.
All my bearings are currently getting DuPont Teflon Bearing Grease (earlier link), but I've also used an off-brand syn automotive bearing grease with good results. (It was on clearance someplace.)
I've also discovered that dribbling One Lube (oil) into the rear freehub body does an astounding job of quieting the freehub's pawls. I mean, it's absolutely amazing! You don't need very much unless you've let it go too long & now it's dried & crusty. A once-a-year dribble is about all you'll need.
