We're kind of reviving this thread, but for the benefit of someone else with the same question, the Touring T/A's were an upper middle class tire in terms of handling. I chewed off 5 sets of them in the N. CA mountains. They came OE on the company issued sedans I used to get. The treadlife was about 30-50% of the aftermarket A/S tour tires I always replaced them with. The T/As handled a bit better at the limits, but I always chose replacement tires with a more aggressive A/S tread design to better handle the late and early snow I had to cope with.
I have a set of Traction T/As on the wifes Celica, and the results have been good. Handling seems very good for an H rated aggressive all-season. Rain performance is also very good. Although the directional tread has a bit of stair-stepping to it, noise has not been a problem yet, and the tires are about 50% worn. Treadlife has been about average - unremarkable either way.
I expected to have to reverse them during the rainless CA summer to prevent them from getting noisy and rough, but that has not been a problem. Overall, I would recommend them for better than average traction in all conditions, and very good performance in heavy rain conditions.
FWIW, I am running a set of Bridgestone Turanza LSV 225/60R16 on my 99 Chevy Lumina sedan, and they are the best tire I have used for street duty. Yes, they are very expensive. They also stick like glue, even and especially on wet surfaces. If you want to go 85mph in a driving rain, there are better choices in tires with a more open tread design, but for all around use, these are great.
Two notes, they are stiffer than you would expect in a touring tire. Not a bad thing in my book, but noticible. They are also noisier than you would expect in a tire that has a conservative, non-directional tread pattern. It is a high frequency sing at higher speeds that I noticed immediately in my vehicle. You may or may not notice this depending on how readily your vehicle transmits high frequency noise.
The tires seem to wear very well, particularly for a V-rated tire. Two thumbs way up on these (but no hands on the wallet!).
[ April 11, 2006, 01:39 AM: Message edited by: mzugg ]
