Consider this:
Many of us strongly endorse periodic pan removals on our transmissions to clean out any accumulated sludge on the inside of our pans, as well as cleaning and/or replacing the filter. Some of these transmissins have auxilliary filtration via an inline filter or a spin-on filter.
Why don't we do the same for our oil pans?
Theoretically, engine oil is exposed to much more contamination than transmission fluid, thus further allowing unwanted buildup inside of the pan. Sure, we drain our oil via a plug, change a spin-on filter, yet some of us own cars with transmissions containing a similar setup, practice religious periodic fluid and external filter changes, yet drop the pan later to be horrified by buildup.
Wouldn't our engine oil pan be even worse? Yes, engine oils have far more detergency than transmission fluids, but the oil still faces much more contamination.
Something to consider...
TC
