Needing a long SUV for my projects and wanting some luxury for "once" I purchased the new Black Label Lincoln Navigator. I got the extended version the first of May this year.
According to their web site:
Capable of producing 450 horsepower* and 510 lb.-ft. of torque,* the twin-turbocharged 3.5L engine in the Navigator** is a true powerhouse. *Horsepower and torque ratings based on premium fuel per SAE J1349® standard. Your results may vary.
**Vehicle shown available at participating Lincoln Black Label Dealers only.
I saw the 0-60 times in as little as 5.5 seconds - attractive for this sports car enthusiast. Note however that these figures assume you are using Premium Fuel. You can use Regular fuel or E85 fuel as well.
The truck is around 6 months old now with around 4,000 miles. Lincoln does free service for the first 4 years, oil changes every 10,000 miles or 1 year intervals. It uses Motorcraft 5-30 fully synthetic oil. It does not get as hot here in Florida as in other places around the country and we do not have any mountains. I never tow anything and never drive over 80 MPH. As such I will be using 5-20 or 0-20 motor oils. As with some others here I could not stand to go 10,000 miles on a single oil change. I chose to put in 5-20 Mortorcraft oil at the 3,000 mile mark. I was hoping to maybe get a little better fuel economy. No change.
It could be that the break-in oil was a 20 grade and that could explain why there was no change. Or there is just not much of a difference as is sometimes the case. If the fuel economy goes down a little after the scheduled change into 5-30 at the dealership in 6 months then we will know the effect of viscosity on my fuel economy. I predict there will be no difference.
I did some experiments with fuel grades in the milage range of 2,500 to 3,000 miles, before the first oil change. Originally I used only premium fuel, mostly Shell. I got 20.5 MPG during this period in my mundane around town driving. I then almost emptied the fuel tank, ran one full tank of Regular gas and then got another tank of Regular and started MPG records again. In fact I have been using only Regular gas since then. Eventually I hit 3,000 miles, changed the oil to a "thinner" one and still had no change in fuel economy. The new readings were 19.5 MPG before and after the oil change.
So I get 5 percent better fuel economy (1 MPG) by using Premium instead of Regular fuel. Even though premium fuels cost more than 5 percent more than regular fuels I will be using it to better the environment by this amount. I have never found that using a 20 grade vs a 30 grade oil made any noticable difference in fuel economy in my cars. But this is a significant difference by using differenct octane fuels.
It occurred to me that we should be using Premium fuel in all cars to get this significant improvement in fuel economy. Maybe we should up the octane of Premium Fuels even higher. Could we get a 5-10 percent better fuel economy rating? Obviously we would have to produce new engines with the necessary timing advancement but we could also retroactively adjust all cars one way or another to take this advantage. Maybe having only one grade of fuel at the station would help reduce its cost making it worth it for the Increased milage.
What say you?
AEHaas
