There was a thread a while back in the "motorcycle" section of this site where I stated that there is no such thing as a "motorcycle specific" filter. I absolutely got pounded for saying that by some people. But the reality is that specs are specs; flow, efficiency, bypass settings, thread pitch, etc all are spec'd for certain criteria. A filter that survives on a little JD/Yanmar tractor can just as easily survive on a HD motorcycle, or a Suzuki outboard marine engine, or a 4-cylinder Yugo, IF the specs are similar/same.
I made the mistake of taking on the HD faithful, tying to use reason and logic about the specs of any engine, and the resultant applications from the major filter brands (Wix, Purolator, etc).
I seriously doubt that HD "requires" a 5um rated filtler, when Wix, Purolator and Champion all offer filters that meet OEM specs with much higher nominal ratings (for example, the 51348 from Wix is 19 nominal). What I really suspect is happening is that HD is "recommending" a tighter, better fitler so that they can offer yet another opportunity for the HD faithful to justify spending more money than necessary on their babies. And that's fine for them; I just don't get sucked into all that hype. I was admonished for my (perceived) lack of knowledge on the HD cam chain tensioner issues. Well, if HD's answer for their continued cam chain tensioner failures is tigher filtration, then why have they not revised the specs?
There is a huge difference between what's "required" to meet specs, and what's "suggested" or "recommended" to appease the audience. Perhaps HD upped the ante, revised the specs, and didn't release the data? Well, then they are in violation of the M/M warranty act; because to "require" a particular item/service for warranty enforcement, without providing it for no cost, nor access to it for aftermarket consumption, is a violation of federal law.
Further, there is no way Wix, Champion, Purolator, etc would risk having to pay out warranty claims for failed engines, knowingly offering filters that don't meet OEM specs. Champion says their ST3614 meets HD specs. Wix says their 51348 meets HD specs. Purolator says their L10241 meets HD specs. I know that when I researched this very topic, I saw that HD offers their 5um fitler as an "upgrade". That, to me, means it's not "required", but rather an opportunity to provide "better" filtration. At a "better" (for HD) price ...
