Simple question...what is the easiest vehicle to change the oil on, and what is the worst?
We already had this thread a couple months ago. Went on for pages.
I think it was a 2001 Mazda Protege Filter was Under the intake, back of engine high in the block near firewall.
Horrendous knuckle and hand mangler. Really had to be done on a lift or ramps. I was never a ramp" guy.
Thanks for swaying me away from the 5.0 genesis. Yikes.The easiest for me is my 2000 Toyota Camry 2.2L. Oil filter is right on the front of the engine, and while I still usually use my ramps, I can drain the oil with the car flat on the ground if needed. 4 quarts.
The worst was my 2015 Hyundai Genesis 5.0L. 2 belly pans, which consisted of about 8 plastic clips and 12-14 bolts, to reveal the canister oil filter and drain plug. Those belly pans went from the front of the car to the back of the transmission. 8-1/2 quarts.
