I've seen three different Ford 300 sixes with the same ticking noises and all had the rocker arms and falcrum seats worn to the point that they would stick the valve open and then throw a pushrod. I hope yours is just dirty oil. Good luck
Well at $4-5/qt, a "couple of oil changes" with GC is gonna run you somewhere in the $40-50 range. An AutoRX treatment, using dino during the clean and rinse phases, will have a similar cost.quote:
Originally posted by Bugshu:
Perhaps a couple of oil changes with GC or another ester based synthetic oil might do as well if used in short drain intervals with frequent filter changes to catch the sludge. Perhaps not.........
Comments?
Did they go to a rocker arm shaft? My 240 (the parent engine) had the traditional stud/half-ball rocker. This is a tough and highly servicable engine (side covers for lifter replacement etc.) I couldn't kill the thing as a teenager in my 65 ex-Uhaul Econoline (suicide center seat/engine cover).quote:
As a side note, I recall that these engines are ones for which there was a special top lube kit made up to route the oil around clogged passages to the rocker shaft. Don't know if they still make it but there must have been some inherent problem.
For all the reasons listed I used Auto RX and will use again. It's a cleaner, not a flush. a lot of cleaning takes place in the rinse cycle.quote:
Originally posted by toolboy62:
but will it work *too well* is the question? I'd love to get this engine cleaned up ASAP but I am afraid of drastic measures. to show you how dirty it is, when I adjusted the valves and replaced the valve seals I took a gasket scraper and manually removed all the gunk from the surfaces of the heads and the underside of the valve covers. I filled up a cat food can with black goo!
I will say that the Rotella that I've been using is slowly breaking it down. I've pulled the distributor twice, the first time I couldn't get the varnish off the oil pump driveshaft, the second time a quick swipe with a rag soaked with Berkebile 2+2 and it looks like new. So it is working, albeit slowly.
I'm just concerned that if I use a product like AutoRX that I may cause more problems than I'm solving... I have a nasty feeling that I may end up having to do a complete teardown but I hate to do that because there's no mechanical problem with the engine...
nate
I feel the same way. I would use it just to make sure my engine was super clean if it were $10 for 12oz. (as I've spent money on other car additives), but I can't justify spending $25 on a decently clean engine.quote:
Im not going to pretend to know the chemistry of the Auto-Rx and some on these boards swear by it yet it seems that $25 per 12 oz. bottle is expensive by any means of measure.
How do you know its decently clean? The rings could be loaded?quote:
posted August 24, 2004 11:21 PM
Yes... I know.quote:
I will say that the Rotella that I've been using is slowly breaking it down. -*-*
