- Joined
- Jul 22, 2020
- Messages
- 416
Good afternoon.
I have a fiberglass batt with a thickness of 17 mm and according to the internet 1 inch=25.4 mm of the fiberglass batt has an r value of 3.5. I also have available to me a closed cell polyethylene foam sandwiched between double sided aluminum foil thermal insulation with a thickness of 3 mm which according to the manufacturer when the thermal insulation finds itself in a system with a space of 1 inch of air has an r value of 12. I sent an email to the double sided aluminum foil manufacturer to ask what r value only the material has as they don't dislose that info on the technical specifications sheet. The double sided aluminum foil available to me resembles this: https://www.amazon.com/US-Energy-Products-Reflective-Insulation/dp/B07QX5LGBX I wonder what kind of r value this double sided aluminum foil has by itself and if an inch of this aluminum foil type insulation has an higher value than an inch of fiberglass batts.
Perhaps a better budget insulation option : aluminum foil paper on the floorpan and then the fiberglass bat?
thanks
thanks
