A FS 5w20 is normally slightly better than a FS 5w30 in winter. You need to use the Widemans visectomy calculator with the two kinematic figures to draw the curves for a real answer, as most cold starts are below the 40c figure.
Some OEM's do not approve 0w20 or 30 oils cos their dealers don't like buying expensive oils.
Make sure you use the approved oil when under guarantee (First year in the UK, but several years in some countries). A warranty can be a nightmare, as you need to prove a failure was not your fault. The stealer will do everything possible to prove it was. Very few engines get fixed after an expensive failure without a legal scrap.
