Those don't look like steel wheels so it is probably only brake dust. Try a little simple green and a small brush, don't leave it on there too long it will stain the coating and make sure to rinse it off thoroughly.Hi
I have a small amount of rust in the corner of my rims
What is the best way to remove and prevent it from coming back
Thanks
ThanksThose don't look like steel wheels so it is probably only brake dust. Try a little simple green and a small brush, don't leave it on there too long it will stain the coating and make sure to rinse it off thoroughly.
Man that's clean!!!!!Iron remover or wheel acid
Thanks all!I have no idea, I can only tell you what I have used that is relatively harmless to clear coats and coatings. I am sure there are some cleaners that are much stonger but they may destroy the finish. Simple Green Aero is also very safe for aluminum and clear coat.
I hit it again and did a coat of wax between gamesA little bit of polish or compound on a rag takes that right off too.
