I would try the M1 10w30 and if you want to make it a bit thicker in the summer just add about 1/2 quart of 15W50; same price and same availability. Can't beat that.
Pedro
Pedro
novadude,quote:
I thought I was daring going to 4500 or so on a high quality dino with 80% highway use in the summer! LOL
This is an Ok idea, but what do you tell them to order? The SKU's and descriptions are identical on all the 0W-30 versions. I found this out when I returned a quart of the made in USA stuff to get a quart of GC. They guy kept saying "why do you need to exchange this? These are the same thing..."quote:
Originally posted by Motorbike:
Autozone will order it for you . It's as easy as that although it does take 1 week and you have to prepay . Might even stock up and buy a years worth .quote:
Originally posted by jsharp:
I've got enough GC for one more change on my Toyota and I'll look around a little bit then. The closest local stores still have the oldest stuff and the stores farther way had a mix of old US and current at the time GC last time I looked. Unless I see some incredible UOA's with it the next 2 intervals I'll probably not bother with it anymore. It just seems silly to me to drive all over Illinois just to find 6 1/2 quarts of oil...
I repeatAutozone will order that oil in for a customer that asks and is willing to prepay ... no more driving around for those that can wait a week .
Will it outperform Mobils 0w-40 Supersyn ? Doubt it if the engine can nicely run a 14 cSt 40wt . That Mobil 0w-40 is some goooood stuff
I should have those results by Tuesday night hopefully. I'm changing the oil this afternoon (gonna try out my new Rhino Ramps-thanks again Al!) and I'm going to drop the sample off directly at the lab on Monday morning so if they aren't super busy it's possible they might even finish it by Monday night (but most likely it'll be Tuesday)quote:
Originally posted by novadude:
I located some "holy grail" GC tonight. IF Patman's 6.2k anaysis looks good, I may go back and buy some.
You're probably right, I think both engines are similar enough that an oil which works well in one would also work well in the other. I wish I had done UOAs on both of my 5.0s, especially when I ran Amsoil 10w40 in one of them, or when I ran 10w30 Mobil 1 in the other one (with a Paxton supercharger on it too)quote:
That's what I want to see! My '95 5.0 sees full throttle at least once per day, and I use my car daily. If GC works well in a gen II Chevy, I expect results will be similar in a 302 Ford.
