I have a by-pass filter. I used to run Mobil 1 synthetic before that, but when I put the by-pass filter on, I went with Amsoil 10w-30. I went with that oil because it had the longest extended drain duration advertised. Thinking that if they advertised that you could use the oil for that many miles without a by-pass filter, it would be even better with the by-pass. I do change out the by-pass filter about every 3-4k miles, and then I top off with new oil (about a quart).
Well, someday my case of amsoil will run out, and I am trying to decide on what oil I should run.
How would you compare the new Moibl 1 extended drain, Amsoil, and the new Pennzoil Platinum, or any other oil you preferr that I don't know about.
Thanks in advance!
Steve
