Not really. The exchanger was $36 delivered off ebay ...plus the advantage is for life. The faster you get to operating temp, the less you tax your fuel economy.
This was, btw, an experiment comparing 15w-40 and 5w-40 for 7500 miles thru the winter. We had both been using Delvac 1 and I switched to Rotella T synth and he to Delvac 1300. Fuel economy on my son's Cherokee was the only issue. No start up or other type complaint was noted. Fuel economy dropped from about 18 for his 16 (approx) commute to around 12. It was almost totally restored with the exchanger due to the rapid warm up of the 4.0 coolant allowing the oil to thin much faster. If left unchecked, the condition would have paced the costs of the exchanger and the D1 costs.
That's why I asked what the service duty of the jeep was and what kinda of "oil guy" the owner is. If it's a relatively short trip commuter, the oil never reaches anywhere near its 100C visc. Hence a 30 weight may work just as well as a 40 weight. A 10w-40 may do fine ..but not if he's into extended drains (or it's a synth).
