Hi, I have a 95 Dodge Colt/Eagle Summit/Mitsubishi Mirage.
It is made by Mitsubishi, and is made in Japan; it has a lovely 5 speed gearbox, matched to a 1.5l 85hp 12valve engine. I just bought a used gearbox from the wrecker, and I would like to drain the oil, and replace with synthetic. I have a good stock of synthetic motor oil, of various grades, so that way I wouldn't have to buy any gear oil for it. I heard that motor oil works just as well as gear oil, so what should I use: i have some Shell Formula 1 5w20 that has a hot cSt of 10-10,8 would this be ok, or should i use a slightly heavier 5w30? I also have some Quaker State synth 5w30, and Penz Plat, 5w30, and probably some synthetic 10w30 as well. I'd like to supplement it with 225ml of Molyslip MoS2 Gear Oil supplement, because I heard this is very good.
