Best Drain Oil Valve ?
Ndx
IL
EZ Oil Drain Valve ? - Cheap and includes hose Fumoto Fram Sure Drain other ? Car 2004 Mazda 3
Yeah I heard that fumoto are great I just don't like the idea that it stands out a lot .. EZ Valve its almost flat ..
OK ok :D It Will be fumoto ... Any good source for those
Lubrication Specialists LLC Look for them on the web. http://lubricationspecialist.com/front/showcontent.aspx?fileid=105 Just ordered one a week or so ago, great service. Also, have 3 others currently installed, used them on two other previous cars. Do not worry about these things leaking or hitting something they are built like a tank. Actually did hti one with a concrete median once, shaved some brass off of the nipple but did not break and still works fine.
Use the Fumoto for the first time last night and it was really easy. I had the little clip on there but I don't wheel my truck so I don't see the need for it.
There was this other brand that I can't remember they been making some good quality valves 2
FEMCO .. thats it :) I think I will go with it ...
So we all tell you Fumoto is the way to go, and you decide on this Femco thing?
I will go with Fumoto because of price .. Femco is 49$ + SH
Naturally! That's why he asked.
there is one at O'reilly's that is around 10 bucks. It can be found on the shelves by the drain plug washers/replacement drain plugs, etc. Not sure if I would trust it, though...Maybe someone else has used it?
Seen them but never looked at them closely. It kinda looked like a Fumoto style valve but with a collar instead of a tab.
