I've already tried Mobil1 15w-50 and it started leaking. So, I'm resigned to either a class 3 or good class 2 dino. Some have suggested diesel oil but i don't believe diesel oil is formulated to withstand issues found in high performance gas engines, i.e. much higher rpm's (no need for anti-foam additives), higher temperatures (diesels run a bit cooler), and the higher zinc and posphorus may foul spark plugs and O2 sensors. I'm firm on a 20W-50, at 127,000mi.
So, what's out there? Kendall used to be good, not anymore. Tried GTX 20W-50, it seemed ok, but some have found it's viscosity unstable. I want something easily obtained not anything you have to send away for. How about Vavoline VR1 20W-50?
Torco?
Torco?
