Originally Posted By: Or
Originally Posted By: 901Memphis
DexronIII is
sometimes only briefly thicker than DexronVI since a mineral DexronIII can easily shear down below 5 cSt @100ºC in 30,000 miles while a DexronVI will probably never go below 6 cSt @100ºC no matter how long you run it.
The DexronVI is
sometimes the superior choice unless you want to use a synthetic dex/merc like Maxlife. Many users rack up tons of miles with the 4T65e using DexronVI and Maxlife being favorites.
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3014880/Improvements_in_DexronVI_over_
If you want get the original Amsoil multi vehicle atf it will stay closer to 7 cSt @100ºC for the life of the fluid although it's not really needed from my understanding.
Fixed that for you.
There are some transmissions that can tell a difference so blanket statements don't cover it all. I know, I own one and other owners note it too - not my imagination. There are quality DexIII's that don't shear so horribly and retain the viscosity. On the synthetic side,
for those picky units, MaxLife turns out not to be so great as it's more DexVI viscosity to start.
Maxlife is even more shear stable than the DexronVI offerings.
My triple edge 4T65e will exclusively use Maxlife and thus far I've had no shifting issues with the fluid.
I think some people expect a fluid to fix a mechanical failure but if it's shifting hard it's probably going to shift hard on anything, and a thicker fluid might just mask it slightly if anything.
I'd much rather have a fluid that stays near its starting viscosity during the entire OCI than one that starts out high and shears.
