- Joined
- Sep 23, 2017
- Messages
- 433
hello my 2003 hummer h2 requires a side post group 79 battery but it is mounted in the hood so it doesnt need the usual vent features of a group 79.
however group 79 is not that readily availabe so i was wondering if you guys recommended any other battery sizes that have similar dimensions to the group 79 but higher or similar cca?
i require about 840cca.
most battery look ups say that i can run a group 78 but i dont want to put a smaller battery in if i dont have to.
the group 78 has a cca of 800 so that seems close enough. so not a bad option but looking for something slightly bigger hopefully!
regardless of the post position, i bet i can just rewire the battery cables and use a top post if i have to no?
th
th
