Originally Posted By: mechtech2
Originally Posted By: boxcartommie22
don't listen to the b/s about how bad k&n filters are all a myth.use that filter!!!...and learn about the pvc system and wide open throttle or just normal driving and then you will understand its not the filter that supposedly put a coat of oil on your maf....also filters far better then a paper filter...ever look in you throttle body after a while you will always find a small fine dust when you wipe with your finger..not with a k&n....i never reuse mine i always buy a new one when you can't see the wire mesh underneath...if you live in a really dusty area or do alot of off roading,then use a pre filter over your filter..
Wrong and wrong.
High silicon levels are common with K+N type filters, and cleaning MAFs is necessary initially after oiling them for a few weeks, and later because of dust.
There are cases here with high silicon numbers on used oil analysis, but there are many that have reasonable (and good!) numbers using K&N as well.
Cleaning MAFs is not necessary without symptoms of a problem.
Wrong and wrong.
