Got my flywheel key on, tried out the mower. I thought it vibrated a bit, so I checked the blade. No wobble, but turns out the part it bolts to (see b&s 193707, whatever that is) is broken. And the blade is kinda worn, and has a crack. So I pulled that off and fired it up. Same sort of vibration.
Before I write this off, does the blade add any sort of dampening? I did not see a bent blade, and the crank did not look bent, but maybe I just can't see it by eye.
