Belt In Oil (BIO) and Oil Spec
Victoria, Australia
Hello!
How important is oil spec in regards to a belt-in-oil driven oil pump as in the Ford 1.5L 3cyl ‘Dragon’ EcoBoost?
This engine has a timing chain, but a belt-driven oil pump. The oil pump belt runs in the oil in the sump.
Ford calls for a 5W-20 WSS-M2C960-A1 but I’d love to run a 5W-30 for longevity. My one and only concern about running a 5W-30 is damaging this belt and causing engine damage.
Are there any 5W-30s around which won’t damage a wet belt?
Thanks for your help
The 1.5 L Dragon engine has an oil bath timing belt.
The non-turbo Dragon has a wet timing belt; the turbo Dragon has a timing chain. Both have wet oil pump belts (except some early versions which had a gear driven oil pump)
Not sure how 5w30 would ruin a belt when 5w20 wont. Some 5w20 are so close to a 5w30 weight and Vice verse.
It’s not the viscosity that concerns me, just that maybe there’s something in the oil that could degrade the belt. The Ford spec includes a test for the belt AFAIK
That’s news to me. Everything that Ive seen says oil bath timing belts for 1.5 Dragon engines. How many versions of this engine is there? Are you in Europe?
From the workshop manual…
But yeah non-turbo Dragons have wet belts; turbo Dragons have timing chain + wet oil pump belt (except very early versions which had gear driven oil pumps)
I wouldn't think they would make a major change like that just to add a turbo. Especially not Ford
Also my engine is the latest variant, and it’s up to ‘Derivative 12’… so, there’s lots of versions of the 1.5 Dragon EcoBoost
Well it’s not “just a turbo”, it’s also dual injection, an exhaust cam-driven HPFP, cylinder deactivation etc.
Lots of differences between the non-turbo and turbo Dragon
I’m thinking it could be a UK or EU thing. The Focus, Focus ST, Fiesta, and Fiesta ST are no longer offered in the U.S.
But the Escape and Bronco Sport are still offered in North America, and they have the 1.5L Dragon EcoBoost! The engine in my (German-built) Fiesta ST is made in Chihuahua, Mexico
Peugeot/Citroen/Vauxhall 1.2 petrol engines in Europe are having big problems with 'wet' belt degradation blocking oil pickup filters.
Was initially put down to faulty belts but they have changed them a few times and still having issues.
OP, my 2021 V8 Ford 5.0 (F150) also has a wet, belt-driven oil pump (cams are very long chains lol). It specifies WSS-M2C961-A1 5W-30. This is the first year using a belt rather than chain. I'm sticking with only oils that meet the Ford spec. My guess is it's also fine for your vehicle.
Just to chime in i habe the 1.5l dragon ecoboost in my 2022 escape. I use it for courier work and change oil every 5,000 miles with motorcraft 5w20 blend. Its got 105,000 miles. Just changed plugs and runs beautifully. 34mpg avg. Highway. Hope it runs a while this wet bet stuff has me nervous? No dealer seems to know what im taking about when i ask about maintaining this said wet belt.
