Originally Posted By: AEHaas
These may help you understand viscosity grades, the first one is more complete:
http://ferrarichat.com/forum/faq.php?faq=new_faq_item#faq_haas_articles
Original article, but somewhat changed by others:
http://www.bobistheoilguy.com/motor-oil-101/
I have used 20 and 30 grade oils where 40 and 60 grades were spec'ed and tested against the recommend OEM oils and found that the thinner grade oils had less wear and tear. Do a search for my vehicles.
aehaas
The way you use your 'vehicles', that is not in the least bit suprising, it is even to be expected.
Use them as they were built and intended to be used (or beyond that) and your results might have 'varied'.
There IS such a thing as going too thin in HTHSV for some apps, as much as most on here refuse to admit it.
What's next, flaming/ridicule for going too heavy for using a 0W-5 spec oil??!!
aehaas
