JHZR2
Staff member
Posted this via PM to a highly knowledgable member, but figure we will all learn something from this, and I've not found the relevant answer on the net, so want to have it out there.
Parents car uses a group 49/H8 battery, which should be a pretty low impedance battery. Alternator charges, battery voltage rises, seems normal. After it sits though, battery voltage drops fairly rapidly (say overnight) to around 12.2V.
So this could mean high self-discharge (high internal impedance or a soft internal short, right?), or a parasitic load, which could be the case since the car is 16 yo and has 220k miles.
Anyway, what confuses me is the behavior when I put a charger on the battery, in the car. If there was high impedance due to sulfation, or a parasitic draw in the connected electronics in the car, charge time should take forever, especially at low rates (I figure a grp 49 is like 100Ah, so I charged at C/10 since my charger had a 10A option).
What happens though is that it goes from where it was sitting, like 12.2V at 85F, up to well past 13V really rapidly (with the charger stating nearly 100%, and this is a charger I use on my personal batteries of similar capacity and trust). I wouldn't have such an issue with this, but it is charging to "100%" far faster than I would expect from a healthier battery of same group/size, starting at a higher voltage.
So the question is, if under charge, using CC/CV down to a very low current, the battery appears to be "fully charged", but has taken far less Ah than it should have, plus the battery rapidly loses voltage, what is this an indicator of? Sulfation? Loss of lead by some other means? Some kind of soft short that allows for a voltage that is not indicative of a 0V or reversed cell, or what?
Obviously a parasitic load test would be optimal, but they don't have the radio security code with them (were together for Memorial day but don't live really close). So I'm trying to understand if there is a way to discern issues/possible battery conditions from what we are seeing.
Any thoughts on this based upon your experience would be most appreciated.
Thanks and happy Memorial Day!
