Decided to try the TRD filter for my Lotus, ordered it through the local dealer. The TRD filter, which xref's to the other, is significantly shorter, which I am not thrilled with, but also not sure if it matters. The weights are similar. Completely different designs. Aside from the visible differences, the TRD has the plastic center tube, a blue plastic Fram like poppet type relief valve, square section sealing gasket and no cellophane cap. The TRD COO is USA, the standard one is COO Thailand.
The bottom pic is the standard Toyota (Lotus branded) filter, cut.
For a car that sees ~year, the size probably doesn't matter...I'll post the cut pics in a year
