I recently watched a video that the companies get a base oil and buy the additive packages (from 3 or 4 other providers) and mix ...
Q1:
In a finished product, what is the base oil volume relative to the additives?
I'm sure it is not the same with every oil but just in general what is the typical amount? For example is it ~%75/25, %60/40, etc.
Q2:
How much or % impact to the fuel economy can be attributed to the additive packages or how is it calculated?
Again, I was reading a thread that additive companies sell different packages that for example can meet GF-x fuel economy requirements ... So when you mix that with the base oil, the fuel economy numbers should change. No?
So how does that work when the final product fuel economy requirements is what should matter or how is it calculated?
Q1:
Q2:
