gathermewool
Site Donor 2023
I’ve been one of the lucky ones who has never had a fuel-related failure in the four seasons I’ve had a house and been running OPE. I know, not that long, but still. I just wanted to say that I’m now on board with using only fresh, stabilized fuel. The below issue could have been worse.
I usually use red Stabil, but ran out and didn‘t add anything to this last batch of fuel. The fuel in the mower was maybe 1/4 full and maybe two months old, tops. Potential cause 1.
Symptoms: died with existing 1/4 tank of fuel after running for 1-1.5 hrs a few weeks ago during my last mow. Would not pull start; wouldn’t even catch. If I manipulated the carb it would rev high and then immediately stall still. I haven’t had time to mess with it until earlier today.
This has happened one other time, dying out of nowhere, but it started when cool. Weird.
Today I added fresh fuel to full - nothing. Not even a hint of starting.
Solution: I emptied the tank. No obstructions noted in the fuel line. I blew carb cleaner through the 8” fuel line, the carb nipple and up into the tank to blow out the screen filter. No other filter was in place but the screen. After blowing into the tank I noticed some fine particulates in the bottom of the tank that weren’t there before. The mesh screen looked shiny and new. Potential cause 2.
I reinstalled the hose, filled with just a little bit of fuel and it started on the first pull. Seems to run stronger through the longer grass, too.
I honestly didn’t think the carb cleaner and fresh fuel would work, it was so dead. I’m glad I didn’t have to pull the carb. It‘s easy to get at, but still.
