i bought a battery back up set up. can i put a bigger battery in the system. i dont realy care if it can go back in the box. back up 650. battery 6 in long, 3.5 tall, 2 in wide.
old metal box?
if so then yes.
for long runs at max loads i add a fan in the bottom blowing in.
and hole in the side near top with a fan grill.
i found a line that went high in inverter mode only and used it to fire off a transistor to turn fan on only when running from battery.
i used an led fan since i disabled the beeper.
so if i see a blue glow under the ups the power is out.
i have run up to 8d heavy equipment batteries.
if you run it any length of time hook a charger to it to speed up recovery.
i have several set up with lighter sockets and anderson powerpoles.
Some designs do not isolate the battery circuit from the power line. This means there may be 120 volts common mode on the battery wiring.
They tend to be really inefficient at power conversion. Also in the cheaper ones there is little heat sinking, the battery is sized so to run down before the converter overheats.
It sounds like you have a 7 amp-hour gel cell. Beware if you hook up a "normal" car battery it will off-gas hydrogen which is mildly explosively dangerous and at times technically not allowed in living spaces.
Originally Posted by OVERKILL
Sure. I used to have an old SmartUPS 1000 that I had hooked up to two car batteries.
Same here - I have the next size (or 2) larger UPS - it had 4ea 6 volt batteries, all in series for 24v.
I just wired two Group 24 Marine/deep cycle batteries together in series
and used 8 or 10 gauge wire to extend the current wiring out to where it can be hooked to the batteries.
I have this setup as well with my server. I need run time but not a ton of amps so this is why I did it. As long as you don't overload what the UPS is capable of you can extend the run time by adding batteries in parallel.
WOW all that info is great. thanks guys. i had a friend that knew all that tech stuff. and i did go throu the electronics school over 25 years ago. but time degrades the brain cells yes i think ill add fuses at the battery, and a disconnect.
