b12 chemtool vs seafoam?
nc
Hey guys, i use seafoam alot. both the liguid in the can/bottle in my fuel, in crankcase b4 oil change, in my vacuum lines to clean im, valves, piston tops etc with one of these: http://www.google.com/imgres?imgurl=http://kwikkarwylietx.com/Portals/0/Fuel%2520Injector%2520Service%2520Small.JPG&imgrefurl=http://kwikkarwylietx.com/KwikKarServices.aspx&usg=__LeLqxeV88nfkCLJj6UW1SQrPp0E=&h=167&w=250&sz=36&hl=en&start=56&zoom=1&tbnid=NA1yHNSo4XVyzM:&tbnh=133&tbnw=200&ei=43CnTdqzLJGUOru66P8J&prev=/search%3Fq%3Dgumout%2Bfuel%2Bsystem%2Bcleaner%2Btool%26um%3D1%26hl%3Den%26biw%3D1024%26bih%3D677%26tbm%3Disch0%2C1956&um=1&itbs=1&iact=hc&vpx=777&vpy=202&dur=41&hovh=133&hovw=200&tx=136&ty=65&oei=13CnTYTgH6KV0QG2ztn5CA&page=4&ndsp=14&ved=1t:429,r:13,s:56&biw=1024&bih=677 - hooked up at the brake booster, and the seafoam spray for tb cleaner.
i was wondering how berrymans b12 compares? safe to add to fuel tank, to add to crankcase b4 oil change, to inject in vacuum lines like i do with seafoam?
thanks guys!
B12 is MUCH stronger than Seafoam......I like the stuff, but I have to say in all seriousness to use it with extreme caution. You can't pour it in your engine and drive around with it like you can with Seafoam.
[censored], i didnt think it was stronger than seafoam. can i use is in my fuel tank and vacuum lines with my fuel system cleaner tool?
