Avoid 30 wt Euro Oils in US?
SW Missouri
I recently purchased a 2017 Audi A4 Quattro. The Owner's Manual said I can use any oil that meets the VW 502 00 or VW 504 00 specification. Looking at http://www.oilspecifications.org/oiltool/oiltool.php I saw there were a large number of 30 wt oils that met the spec. However, when looking at their specifications, I noticed they all had TBNs in the 7-8 range. The 40 wt oils OTOH generally had TBNs in the 10-12 range.
My concern is whether an oil with a TBN of 7 -8 can stand up to the 10,000 mile OCI recommended by Audi. That may be fine in Europe where they have low sulfur gasoline, but I have concerns about using them in the US where our gasoline currently can contain up to 300 ppm.
Thoughts?
If it meets VW 502.00 spec, then it likely also meets ACEA A3/B4, in which case it will have TBN of 10 minimum.
If it meets VW 504.00/507.00 spec, then it will have a lower TBN / lower add pack in order to protect emissions equipment on modern diesels.
Just stick to something that meets VW 502.00 spec and you'll be fine. If you want an Xw-30 oil that meets it, Castrol Edge 0w30 is a good option.
Originally Posted By: wemay
Not positive, but I thought the US switched over to low sulfur fuels recently. If mistaken, someone will correct.
It's a work in progress. For now, the only place that will guarantee ultra low sulfur gasoline at every pump is California.
Nay, nay, good poster. Many of the 30 wt Euro oils which meet the VW 502 00 spec don't meet the ACEA A3/B4 spec. here are a couple of examples:
https://s3-eu-west-1.amazonaws.com/motul....pdf?1492017670
https://pim.liqui-moly.de/pidoc/P000336/8936-TopTec46055w30-24.0-en.pdf
This one is A3/B4, VW 502, but has a TBN of 8.8. http://catalog.lubricants.total.com/gallery/ORIGINALS/visuels/5500/5903
OK, my bad then. I've never seen these oils at retail. Basically, A3/B4 spec requires a TBN of 10 minimum.
That total oil is POS if they claim ACEA A3/B4 with TBN of only 8.8.
With that said, I don't think you're going to have any issues running an approved oil with TBN of 8 for 10k miles. There is a 1 year limit on your OCI as well.
Your link is for 5w30, not 0w-30.
Not so sure about Castrol Edge 0W-30. According to this, it's VW 502 00 and ACEA C3. I'm thinking it would have a TBN in the 7 -8 range. https://www.amazon.com/Castrol-Professional-5w30-Synthetic-Motor/dp/B071KLGJNK
Forget TBN. This is not a group I diesel oil. Certain preferred long drain basestocks do not require high TBN.
- 10K OCi? Unless I had a 7 litre sump or drove 3K miles / month on the highway = NOGO.
- Oil weight is universally about 7.3lbs/ Gal.
You must mean oil grade; e.g: 30, 40, 50
I apologize in advance for being a %7^^$)
This is the one I'm talking about:
https://msdspds.castrol.com/bpglis/Fusio...BPXE-A9TNQ9.pdf
Thoughts?
The 504.00 oils have the TBN 7-8.
502.00 should have a higher TBN.
FWIW I just had a 9100 mile run with Schaeffer 9000, TBN listed as 7 - 7.5. TBN list of the 7.5; UOA said it could go further as TBN was still good.
I know, I know, different oil different application however I am addressing OP's concern that a 7 to 8 TBN is not enough for 10,000 miles.
You're correct, thanks for pointing that out.
Thoughts?
Can you provide a reference for 502 00 TBN requirements? Audi says Liqui Moly Top Tec 4605 SAE 5w30 meets the 502 00 spec. Liqui Moly says it has a TBN of 7.4 https://pim.liqui-moly.de/pidoc/P000336/8936-TopTec4605SAE5w30-24.0-us.pdf
I've got a 5 litre jug of Liqui Moly 2244 5W30 Top Tec 4605 on the way. It's approved for the 502 00 spec with a TBN of 7.4. I think I'll use that for my next OC and have it analyzed at 5000 and 7500 miles.
