First of all, I am new to this forum but I have been changing my own oil for almost 30 years.
Background:
I live in the Houston area, and my beat-to-death Chevy K-10 4X4 4.3L V-6 hunting truck has 110K miles (lots of "hard" miles) on it. I have always used either a synth-blend or full synthetic oil with 3K OCIs, and my old truck runs great. I read all the good things in this forum about Autorx, so I bought a bunch of it; I have been through one Rx cleaning cycle in this truck, and I am on the tale end of the first 2K miles "rinse" cycle.
I am am leaving for a two week hunting trip in Colorado right after Labor day. It is almost exactly 1000 miles from my house to where I will be hunting in Colorado, and since I am trying to follow the high-mileage/fix-the-seal-leaks Rx directions and use conventional oil for the second Rx 1K miles cleaning and 2K miles rinse cycles, my trip to Colorado appears to be an excellent time to finish my Rx processes.
The scenario:
Temperatures during my hunting road trip will range from 90+ degrees in Texas to 20 degrees in the mountains of Colorado. I have lots of different motor oils in my garage, so here is what I was thinging about:
1) Change oil/filter just before leaving for Colorado with either Chevron Supreme 10W30 or Havoline 5W30 + Autorx.
2) Begin Rx "rinse" cycle in Colorado with a new filter and use either Havoline 5W30 oil or Trop Artic's excellent 5W30 oil made from group II stock. With temperatures in the Colorado mountains as low as 20 degrees, 5W30 oils would seem to be the right viscosity to use while in Colorado, and either oil should be able to handle possible 90 degree temperatures during the trip back to Houston.
Because I am new to Autorx, I am solliciting any & all opinions regarding which oil or oils would work best in the scenario described above.
Thanks in advance!!!
Background:
The scenario:
