auto-rx in power steering?
Schaumburg
My friend has a pretty big PS leak in a 94 supra...
Is the auto-rx for trans, PS, rear diffs the same as the engine auto-rx, or are there 2 different products? which one should be used in the PS (if there are 2 diff products)
They are the same, you can find the instructions for various applications on the ARx website. I don't have the URL handy, but Google does.
same thing but if his leak is a bad seal then juust fix it cause auto rx isnt a genie in a bottle...it fixes small minor leaks not ones that are caused by bad seals or warped ones.
Where is the p/s system leaking? Rack? Hose/hose fitting? Pump? I had a very minor leak (dime sized drip on the ground each morning) at the passenger side of the rack which Auto RX took care of. Digital is right, though, I doubt it'll do much for a big leak.
Not sure... the dummy put in some BARS leak PS leak stopper and now he said his steering is all hard LOL
Hes buying a few bottles for other cars, so I figure we can just put a tiny more in the PS pump, its hard to work on, its a 1994 TT supra, modified to a huge single turbo...
