We have attempted to configure out instructions to serve the most customers with the highest value in results and costs. The current instructions give a good balance of minimizing costs due to rapid oil changes while getting the full effect of Auto-Rx. This works very well for most customers and is required for sludged engines and highly recommended for all other conditions. However, the fundamental impact of Auto-Rx can be compressed into a shorter cycle. It will cost more in motor oil and filters over the miles in use. If those costs aren't a factor, or your time base will mean stretching the normal instructions out too long in months, OR if you're need to get the cleaning and rinsing over with sooner as to get back to a PAO or Ester based oil that is a requirement of continuous operation, then this "Fast Track" method may be for you. Again, we feel that the slower method gives the customer the maximum value in totol costs.
